Hello Guest it is November 22, 2026, 06:35:19 PM
Author Topic: I'm having trouble referencing home  (Read 8358 times)
Offline TFT
  •  17 17
« on: April 28, 2016, 06:36:27 PM »
I have five axis in total,
for X Y and Z i have the limits and home setup. each axis has a single pin on the parallel port.
Everything is working fine with X Y Z axis, when i say reference home they go to the switch then stop and back off.
Now the problem is with axis A and B, i set the switches up the same way, each has a pin shared with limit and home, yet when I reference home they ignore the switch and crash.
I dont get it, everything is the same I think... And furthermore, in diagnostics, if I press the limit switch for A or B all three yellow lights trigger for Limit+- and home.
Any idea what the problem may be?
Offline TFT
  •  17 17
Re: I'm having trouble referencing home
« Reply #1 on: April 29, 2016, 10:31:37 AM »
BTW I have tried de-bounce 0 500 2500 3000, and still it hits the home and crashes.
