Mach Discussion => General Mach Discussion => Topic started by: TFT on April 28, 2016, 07:36:27 PM
I have five axis in total,
for X Y and Z i have the limits and home setup. each axis has a single pin on the parallel port.
Everything is working fine with X Y Z axis, when i say reference home they go to the switch then stop and back off.
Now the problem is with axis A and B, i set the switches up the same way, each has a pin shared with limit and home, yet when I reference home they ignore the switch and crash.
I dont get it, everything is the same I think... And furthermore, in diagnostics, if I press the limit switch for A or B all three yellow lights trigger for Limit+- and home.
Any idea what the problem may be?
BTW I have tried de-bounce 0 500 2500 3000, and still it hits the home and crashes.
