Hello Guest it is November 02, 2026, 10:07:53 PM
Author Topic: Weird rotary axis issue???????????????  (Read 67982 times)
Offline rcaffin
  •  1,073 1,073
Re: Weird rotary axis issue???????????????
« Reply #50 on: May 08, 2016, 09:40:04 PM »
Well, if it's a bug, then the bug works very well.
Yes, I actually agree, but I think (I am very sure) the bug is a programming error rather than a random corruption. (I have about 50 years of programming experience.)
I wrote the code for this from scratch. I may have mentioned it in Gearotic recently. It runs, and makes GT2 pulleys.
cheers
Roger
Offline dude1
  •  1,253 1,253
« Reply #51 on: May 08, 2016, 11:12:41 PM »
yer you did if it works it works
Offline rcaffin
  •  1,073 1,073
« Reply #52 on: May 08, 2016, 11:19:46 PM »
True.
Fwiiw, going from XL belts to GT2 belts seems to have improved the zero-holding from 0.15 mm to 0.5 mm, so I think it was worth while.
Roger
Offline dude1
  •  1,253 1,253
« Reply #53 on: May 08, 2016, 11:40:21 PM »
my 3D printer use's GT2 pulleys and belts and it's quite good at 5000 mm/min
Offline rcaffin
  •  1,073 1,073
« Reply #54 on: May 08, 2016, 11:45:44 PM »
Aaarrgghh ! ! !
That should be be:
'improved the zero-holding from 0.015 mm to 0.005 mm, ' (15 microns to 5 microns)
What was I thinking????
Gerk
Roger
Offline dude1
  •  1,253 1,253
« Reply #55 on: May 09, 2016, 12:04:24 AM »
that's better that's where I would like my big router to be at all the time but it's big so 0.01 to 0.00 over 1000 movements on a single axis is good, I just have to keep it at 1250 mm/min any faster it's moving out by mm at a time in any direction. but it's a easy fix $1200 worth of new parts it came from bad advise years ago lesson learnt only listen to experienced users that have a good name on here not the others.
