Hello Guest it is October 20, 2026, 03:07:17 PM
Author Topic: Best way to combine g-codes generated from Conversational?  (Read 10550 times)
Machinists,
I like to use the conversational machining to make g-codes.Ê When I post a g-code the are saved as "NewProgram.tap".Ê I then change the name to make it memorable.Ê I now have several g-codes and would like to combine them so I don't have to open a new one for each machining sequence.
What's the best way to combine them?Ê cut and paste when "Edit G-code"-ing or is there another way?
MM
ps: found out this forum doesn't like Firefox.
« Last Edit: May 18, 2007, 10:21:29 AM by Marmot_Militia »
Re: Best way to combine g-codes generated from Conversational?
« Reply #1 on: May 18, 2007, 12:14:02 PM »
You can open them in notepad and edit all you like :D
« Reply #2 on: May 18, 2007, 12:19:21 PM »
That is odd I use fire fox all the time
www.newfangledsolutions.com
www.machsupport.com
« Reply #3 on: May 18, 2007, 12:38:53 PM »
Brian,
I get the funky garbage-text when I hit return in Firefox (using it now)
but it formats correctly in Safari.
Oh well,
MM
