Hello Guest it is November 13, 2026, 12:32:36 PM
Author Topic: Getting my c11 board to control my spindle but am having an issue  (Read 7596 times)
I'm redoing an old cnc lathe with all new electronics. The lathes spindle motor is a dc servo motor. To power it and control it I am using a bardac 1600i drive. Last week I was able to successfully wire up the bardac to control the spindle manually with the use of a pot. I now want to control it using mach 3. I purchased a c11 breakout board but am confused as to how to wire it. The c11 has a analog 0-10v output. I have a +12v psu that powers the analog just like the manual says. I then ran a wire from the analog to terminal 3 on my bardac. Is that all I need to control the spindle speed? What would I need to set the spindle pins at in mach 3 considering its only using the analog. I attached the bardac manual if anyone is able to help me out. Thank you
