Hello Guest it is November 22, 2026, 03:37:08 PM
Author Topic: Motors start then stop then contunue when Back Lash is enabled.  (Read 12500 times)
Hello All,
Can someone please help.  I am not sure what is wrong with my settings.  I just installed the most receint version of Mach3(verision .070).  When I jog either the x or y axis, the motors move a little then ramp down to a stop then ramp back up to full speed.
This also happens when I run a program.  If I disable the back lash the problem goes away.   Any Ideas?
Jose.
Re: Motors start then stop then contunue when Back Lash is enabled.
« Reply #1 on: May 18, 2007, 08:07:30 AM »
To speed up the time of the backlash correction set your lower your Shuttle time. it is under the General configs .
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 18, 2007, 11:27:42 PM »
Thanks,  I used  .01 sec. I just guessed this value. Would you recomend this or a different value?  What exactly is this any way?
« Reply #3 on: May 19, 2007, 09:01:33 AM »
Ths is the time to ramp down the axis for the backlash correction. If you think it can do it faster make it smaller :)
www.machsupport.com
