Hello Guest it is November 13, 2026, 11:00:36 AM
Author Topic: switching between mm & inch format  (Read 8040 times)
« on: April 06, 2016, 04:58:15 PM »
Hi. I've  just started  using  Mach 3 on a small   (Chinese ) engraving machine and I would  like  to  know  how  to  switch  between  mm and  inch units. I don't  see  a toggle  for  this  on any of the  Mach screens. I've  configured the machine  set-up parameters  using  millimeters , but some  of  the  G code I use is in inch format .
Also, I'm  having  the  same  trouble  selecting the  right  coordinate  system, resulting  in horrific  crashes  :'(
Any help  would  be  welcome .
Bruce
Re: switching between mm & inch format
« Reply #1 on: April 06, 2016, 05:46:57 PM »
All you really need to do is put a G20 at the start of your inch g-code file.
Ideally, though, you should have two Mach3 profiles. One with the machine set up for mm's, and one set up in inches.
