Hello Guest it is November 22, 2026, 03:52:36 PM
Author Topic: Motors ramp up with each line of g code??  (Read 24216 times)
« on: May 17, 2007, 06:35:29 PM »
Hello,,
I have things up and running, all my hardware problems are solved, now all I need to do is learn how to program g codes.. It seems when your g code starts another line the motors will slow down and ramp up on evey line of g code. If I am already moving in X+ direction during a line of g code and in the next line I am still going in X+ direction is there a way to keep my speed in x+ direction??
Thanks to all
Josh
Re: Motors ramp up with each line of g code??
« Reply #1 on: May 17, 2007, 07:16:11 PM »
Put a G64 in the Gcode file and you should be good to go :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 18, 2007, 08:12:15 AM »
Thanks for the response
but unless I am putting it in the wrong line, it still pauses between Gcode lines??
« Reply #3 on: May 18, 2007, 08:16:55 AM »
Please post what you are running for a program and we will see what we can do.
Brian
www.machsupport.com
« Reply #4 on: May 18, 2007, 08:33:37 AM »
Thanks for the intrest Brian,,
I Built and Induction Heat Treat Scanner run by stepper motors,, Im sure the programing looks like childs play to you.
M3 turns on a dc motor that spins the part, M7 turns my induction heater on, and M9 turn the induction heater off, but what is happening is there is a momentary puse right when it shut my induction heater off,, witch really is not a big deal but the heated steel needs to get into the quench as quicky as posible,  to become harden.
thanks
josh
M3
M7
G0 X-05.000 Y00.00000 Z00.00000
G0 X-08.000 Y00.00000 Z00.00000M9
G0 X 00.000 Y00.00000 Z00.00000
M30
« Reply #5 on: May 18, 2007, 08:45:08 AM »
Try this :
M3
M11 P1 (P is the signal number)
M10 P1
M30
This will turn on and off outputs and never stop :)
Hope that helps
Brian
www.machsupport.com
« Reply #6 on: May 18, 2007, 09:12:51 AM »
I ran that there was no pause but it didnt turn on my relay,, P1? is that pump 1, input 1?
« Reply #7 on: May 18, 2007, 09:14:59 AM »
I mean output #1
« Reply #8 on: May 18, 2007, 09:15:53 AM »
The P number is Output number 1-20
Sorry about that
Brian
www.machsupport.com
« Reply #9 on: May 18, 2007, 09:17:35 AM »
sorry still thinking
p means output pin # Im on pin 16 so I would put P16
