Hello Guest it is November 01, 2026, 10:12:38 AM
Author Topic: LazyCam 2.01 Lathe  (Read 24046 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
LazyCam 2.01 Lathe
« on: May 17, 2007, 03:34:35 PM »
Hi, Art & Brian
LC is working nice:
Origin Mouse move is working hear just fine now, No Crashes So-Fare !.
Hears a couple of little Issue, Just to keep you from getting Board.
Ruffing Cut to Long.
Right Arc differs from Left Arc, The last picture. is correct Now.
Going to be Au-Some, Thanks, Chip
« Last Edit: May 17, 2007, 08:47:23 PM by afn09556 »
Re: LazyCam 2.01 Lathe
« Reply #1 on: May 17, 2007, 08:50:41 PM »
Lathe will get a BIG update after we are done with mill and plasma :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 25, 2007, 08:17:51 PM »
Chip can you post your .lcam file please
Have a nice Day
Offline Chip
  •  2,055 2,055
« Reply #3 on: May 25, 2007, 08:34:48 PM »
Hi, Wnevels
It's right below the first picture, second Red Download Button.
Thanks Chip
« Reply #4 on: May 25, 2007, 08:40:38 PM »
Hmm ok i was looking for the .lcam file to see what settings you are using
I loaded that .dxf file and when i get to mach its excatly opposite of what i see on yours.
Have a nice Day
Offline Chip
  •  2,055 2,055
« Reply #5 on: May 25, 2007, 08:49:22 PM »
Hi, Wnevels
Hear you go wasn't paying attention hear, I think this is it.
Thanks Chip
« Reply #6 on: May 25, 2007, 08:53:52 PM »
Chip thanks for the .tap file
Have a nice Day
« Reply #7 on: May 26, 2007, 01:58:47 AM »
whew i finally got Lcam turn to work, its really cool once you get it.
thanks
Have a nice Day
« Reply #8 on: May 26, 2007, 04:37:54 PM »
anybody know how to fix the void in the face arc?
Have a nice Day
Offline Chip
  •  2,055 2,055
« Reply #9 on: May 26, 2007, 06:51:32 PM »
Hi, Wnevels
It's your tool spec's/cutter that limits the cut path, You'll need a tool change to get in there.
It would require a different tool and a different layer to cut it, left or right with a appropriate back angle setting than what your using now.
Post your DXF file, You can cut it out as it is then create a second file to do the curve cut with a different tool.
Don't think LC lathe is to that point rite now.
Hope this Helps, Chip
« Last Edit: May 26, 2007, 08:29:28 PM by afn09556 »
