Hello Guest it is November 13, 2026, 08:54:22 PM
Author Topic: xml transfer  (Read 9291 times)
Offline PCH
  •  80 80
xml transfer
« on: March 28, 2016, 09:35:46 AM »
 :-\Just put Mach3 on a new hard drive and got my license to load up.
Now I need to get the xml file that I was using into the Mach folder
so things will run the same as it did on the old hard drive.
Need a walk thru to do this.
  •  9,377 9,377
Re: xml transfer
« Reply #1 on: March 28, 2016, 10:28:13 AM »
Your last used .xml file will be in the C:\Mach3 folder of your old drive and it will be called <your profile>.xml (typically Mach3Mill.xml). Copy and paste this file into the C:\Mach3 folder of your new drive.
Offline PCH
  •  80 80
Re: xml transfer
« Reply #2 on: March 28, 2016, 11:21:42 AM »
hey thanks so much....I will do that
