Hello
Guest
it is
November 22, 2026, 11:15:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
xml transfer
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: xml transfer (Read 9340 times)
PCH
80
xml transfer
on:
March 28, 2016, 09:35:46 AM »
:-\Just put Mach3 on a new hard drive and got my license to load up.
Now I need to get the xml file that I was using into the Mach folder
so things will run the same as it did on the old hard drive.
Need a walk thru to do this.
Logged
Tweakie.CNC
9,378
Super Kitty
Re: xml transfer
Reply #1 on:
March 28, 2016, 10:28:13 AM »
Your last used .xml file will be in the C:\Mach3 folder of your old drive and it will be called <your profile>.xml (typically Mach3Mill.xml). Copy and paste this file into the C:\Mach3 folder of your new drive.
Logged
PCH
80
Re: xml transfer
Reply #2 on:
March 28, 2016, 11:21:42 AM »
hey thanks so much....I will do that
Logged
Print
Pages:
1
Go Up
« previous
next »
