Hello Guest it is November 13, 2026, 03:32:57 AM
Author Topic: having ref all probleme can anyone help me out  (Read 22148 times)
Re: having ref all probleme can anyone help me out
« Reply #10 on: March 28, 2016, 05:53:09 PM »
You Where saying
 that 066 si in bas shape si what version should  i download
« Reply #11 on: March 29, 2016, 02:28:18 AM »
Ok, well if it is reaching the switch and not triggering an E-Stop then it must be backing off until the switch has again closed. It may just be that the switch is sensitive and you do not physically see the backoff.
You will find 062 here
ftp://anonymous:guest@machsupport.com/Mach3/Mach3Version3.043.062.exe
« Reply #12 on: March 29, 2016, 05:28:41 AM »
That is the version i am using right know. some one esle had suggested me that. With that version i can at least ref my x and y but the z not yet.
i tried yesterday to check programing did the set set up again distance travelled. when i shut it down it ask me to save fixtures i said yes. today i will try to ref all to.
My question  today is about the distant traveling back.
the z should you place  -2 in the home off since its travelling away
Offline Mogal
  •  76 76
« Reply #13 on: March 29, 2016, 02:14:07 PM »
Can you trigger the limit switch with your finger to verify the limit is in fact working?
One other thing I had to do, was increase the debounce on my system to 250 to allow the switch time to reset during the ref command.
(Not sure is thats the right thing to do, but it allowed the system to work correctly)
« Reply #14 on: April 16, 2016, 04:14:06 PM »
Hello
 i redid a profile
it seems to work a bit better but still having probleme with x home
the picture in the machine window seem to be up side down
They seem to p^rint mirrow
