Hello
Guest
it is
November 13, 2026, 08:05:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Slaving an axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Slaving an axis (Read 7792 times)
BarryM
21
Slaving an axis
on:
March 20, 2016, 06:55:22 AM »
I have a 3 axis controller I'm using the X,&Y axis Z is open I need to slave my x axis can I use the Z axis as the slave? I went into mach3 to the slave drop down but how do you set up the correct slave?
Logged
ger21
6,295
Re: Slaving an axis
Reply #1 on:
March 20, 2016, 07:23:18 AM »
Go into ports and pins and configure the "z axis" on your controller to be the A, B, or C axis.
Logged
Print
Pages:
1
Go Up
« previous
next »
