Hello Guest it is October 22, 2026, 09:33:50 PM
Author Topic: NFW Cut Circle  (Read 32417 times)
vmax549
NFW Cut Circle
« on: May 16, 2007, 09:13:45 PM »
ROn the NFW cut circle has gone waky. It is back to cut a small jog outside the circle radius again and also when the cutter reaches 180 deg of the circle it retracts to safe z and takes off at a 45 deg angle atfull speed towards what looked like the "reference" position untill it hits the switches. I caught it before it slamed into the switches. No matter what the settings I used it did the same thing. I also rebooted the computor and still the same. ????
I tried the other cut circle in the wizards by Karin(??) and it worked perfectly, back to the nfw and it did the same thing again???
vmax549
Re: NFW Cut Circle
« Reply #1 on: May 17, 2007, 09:58:44 AM »
Problem update:
If I open the wizard and do" not" change the Z depth of steps for cut , it does not take off at the 180 deg point but the little jog inside the circle still remains at the point it starts the arc to cut.
So far I can change any setting but that one and it does not take off at 180deg.
 (;-) Tp
vmax549
Re: NFW Cut Circle
« Reply #2 on: May 17, 2007, 03:15:15 PM »
Problem update:
Ron, I upgraded to the latest version of Mach and the problem so far has gone away. (;-) TP
