Hello Guest it is November 13, 2026, 07:59:50 PM
Author Topic: Mirrored model  (Read 12097 times)
Mirrored model
« on: March 12, 2016, 07:13:30 AM »
Hi.
I have a small issue with my cnc 2030 which I bought lately, and Mach3
I design with Artcam express program, and when I load g-codes, the machine starts engraving mirrored the model I've designed.
If anybody knows how to fix it, please help.
Best regards.
Re: Mirrored model
« Reply #1 on: March 12, 2016, 07:44:50 AM »
Your axis is running backwards in Mach3. Go to Config > Homing/Limits, and check the Reverse box for the mirrored axis.
Re: Mirrored model
« Reply #2 on: March 12, 2016, 09:00:21 AM »
Thank you.
Need to check X and Y only, or Z too?
Re: Mirrored model
« Reply #3 on: March 12, 2016, 09:03:49 AM »
Only the one that's mirrored.
Re: Mirrored model
« Reply #4 on: March 12, 2016, 08:38:38 PM »
Thanks a lot. Problem solved  :)
One more question ..
When I load G codes and program start engraving, sometimes starts drill deep hole which is not programmed and breacks the bit.
Can you help me with that too?
Best regards.
Re: Mirrored model
« Reply #5 on: March 17, 2016, 06:15:52 PM »
Can't believe I had the same problem Thanks ger21
