Hello Guest it is October 22, 2026, 07:42:44 PM
Author Topic: spindle RPM issues  (Read 8772 times)
Offline Toad
  •  58 58
spindle RPM issues
« on: March 03, 2016, 08:51:52 AM »
Good day friends,
I replaced my spindle with a 4.0kw spindle.
Let me see if I can explain it.
 for some reason, my indicated rpm's on the inverter and mach are not correct.
The spindle has a top speed of 18000 rpm's @ F300.
In mach, when you reach 8000 rpm's, Inverter also says 8000 rpm's but Spindle is running wide open, and will not go any faster. Like it has a range is set for 0-8v instead of 0-10v.
If I check it with a meter, the board is putting out 6 volts, the spindle is running at full speed. It will ramp down when voltage is lowered, but indicated rpm's cant be correct.
In the inverter manual, PD070 for analog input , #1 is for 0-10v that is where I have it set.
It really has me puzzled. Baud rate is set for 9600.
My settings on the inverter are:
PD001 =1  0-10v
PD002=1  Controlled by external board
PD003=300 max frequency for 18000 RPM
PD004=300 Max frequency
PD005=300 Max frequency
PD070=1 analog input
PD072=300  Max frequency
any assistance will be appreciated.
I've contacted manufacturer, but have not heard back yet.
Offline Toad
  •  58 58
Re: spindle RPM issues
« Reply #1 on: March 04, 2016, 08:28:41 AM »
OK, found the problem.
In the inverter, PD144 was set for 1400 changed it to 3000 and everything started working correctly.
Toad
