Hello Guest it is October 24, 2026, 07:07:02 PM
Author Topic: USB ports and pins versus printer port  (Read 7954 times)
« on: March 02, 2016, 07:24:16 AM »
The Mach soft ware seems to be set  up for printer port  port and pin numbers , My DMB4250-8B Breakout Board supports both usb and printerport.  How do I designate using a usb port instead and what happens with the port and pin numbers ?  I am really a newbie in this area.      thanks,   Chris
Re: USB ports and pins versus printer port
« Reply #1 on: March 02, 2016, 07:32:08 AM »
The USB port on that board only provides 5V to the board. It's not used to send/receive data.
See pages 8 and 9 in the manual.
http://www.dmm-tech.com/Files/DMB4250-8B_BreakoutVer010106.pdf
« Last Edit: March 02, 2016, 07:34:20 AM by ger21 »
