Hello Guest it is October 21, 2026, 08:56:49 AM
Author Topic: Help please  (Read 56447 times)
Offline Jacko
  •  43 43
Re: Help please
« Reply #10 on: February 29, 2016, 03:45:28 AM »
I am now going to try using IE as it wont work with Chrome
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Help please
« Reply #11 on: February 29, 2016, 04:05:26 AM »
That's not your xml file - that looks like a copy of MachXML.exe which is an executable. I asked for Mach3Mill.xml.
Offline Jacko
  •  43 43
Re: Help please
« Reply #12 on: February 29, 2016, 04:20:18 AM »
Whoops - sorry .  Try again.  Hopefully get the hang of it  one day !!
Offline stirling
  •  2,188 2,188
  • UK
Re: Help please
« Reply #13 on: February 29, 2016, 06:35:41 AM »
OK - try this:
go to folder c:\Mach3
Make a copy of the file 1024.set file
delete the 1023.set file
save the attached ZZZ1023.set file
remove the ZZZ from the filename
i.e. you should now have a new 1023.set file
run Mach as normal
Offline Jacko
  •  43 43
Re: Help please
« Reply #14 on: February 29, 2016, 09:17:16 AM »
Fantastic - it worked !! You are a star.  Many thanks.
Was it me mucking about with that script for the tool probe that caused it?
Offline stirling
  •  2,188 2,188
  • UK
Re: Help please
« Reply #15 on: February 29, 2016, 10:00:00 AM »
Yep - corrupt scripts in the screenset can do this.
Re: Help please
« Reply #16 on: December 11, 2021, 11:52:30 AM »
OK - try this:
run Mach as normal
  Old post but I'm having the same issues. should all those files be 1024??? cant find 1023
Re: Help please
« Reply #17 on: December 13, 2021, 12:47:34 PM »
Anyone finding this via search and has the same problem... Yes all those files should read 1023.
