Hello Guest it is November 13, 2026, 11:59:40 AM
Author Topic: SPINDLE FREQUENCY?  (Read 9350 times)
SPINDLE FREQUENCY?
« on: February 16, 2016, 11:17:41 AM »
I bought and installed a 1.5kw water cooled spindle which is run by a requisite inverter. Now whenever I switch the spindle on it triggers the limit switches and I can't reset it until I switch the spindle off. I'm virtually at a stand-still. Any help? The spindle runs independently of the Mach software by the way.
Re: SPINDLE FREQUENCY?
« Reply #1 on: February 16, 2016, 12:50:39 PM »
I am a newbie here and still learning, but sounds like you need shielded cable. I am sure the more experienced  people here can explain but the electrical noise from the inverter can trigger an Estop
Bill
« Reply #2 on: February 17, 2016, 09:44:35 AM »
I think you may be right Bill, so I'm going to do just that...fingers crossed. :)
« Reply #3 on: February 18, 2016, 08:57:11 AM »
You can add some debounce to your settings... That will aide in removing or masking some of the noise
Check your cable routing.
You can add some 0.1uF ceramic capacitors (100nF)
Rob
Rob
