Hello Guest it is November 13, 2026, 12:00:37 PM
Author Topic: When I Hold Feed then Start Cycle, A axis abruptly turns;-(  (Read 19443 times)
Re: When I Hold Feed then Start Cycle, A axis abruptly turns;-(
« Reply #10 on: February 18, 2016, 08:30:02 AM »
I saw that too, but  no configuration instructions at all for the actual device/plugin like others.
Still, a plugin is a plugin.
« Reply #11 on: February 18, 2016, 08:59:42 AM »
The translater helped  :)
"Once inside the program will be used the Mach3 setup tools, you don't need to configure "Port" or "Pin" of output, these come pre-defined default interface"
Thanks Gerry
Offline Frank1959
  •  38 38
  • Do it, it´ll free your mind.
    • Monumental Sculpture
« Reply #12 on: February 22, 2016, 08:04:29 AM »
Thanks guys for your input on this issue. Something has comne up, and I have to leave aside looking for a solution, but hope to soon get back to it.
Step 1 will be installing the older MACH  version, and then tests, and if that fails, I will contact SUCARMO.
Regards, and thanks,
Frank
