Mach Discussion => General Mach Discussion => Topic started by: Frank1959 on February 16, 2016, 08:25:25 AM
Hi all!
I´m at present doing 4 axis machining of polystyrene foam, using DESKPROTO to generate g-codes, and an A axis to spin the part.
I´ve just noticed something strange and problematic in MACH3 when I need to pause in the middle of a routine.
I touch the FEED HOLD button on the MACH screen, and within a few seconds (probably MACH needs time to reference where it is to ready itself for starting again)…MACH pauses, as if on Hold. Fine up to here.
But when I wish to re-commence, and I click on the Cycle Start button on the MACH screen, the A axis mysteriously and abruptly spins to Machine Zero, no matter what angle the routine has been working at, and milling commences.
Attached a Screen Shot: you can see the a axis is now at 1.9125º, bt it should be at 0º. (which it this case is actually 0º at Machine Coordinates)
And if it had been working at say 270º, as happened some days ago, it still spins abruptly to Machine Zero for that (A) axis.
Am I doing something wrong here??
Thanks!!
If its not obvious, I´m pretty much of a new-comer
parallel port, or motion controller?
What version of Mach3?
Now that I think about it, when I was milling my pistol grips, this happened to me. I was cutting a 3d code with no A axis movements from Aspire.
Motion controller is a USB Smooth stepper.
mach version is either .061 or .066 Dont remember exactly right now.
Its a USB port Im using, so I suppose...Motion Controller?
As for the version of MACH3, I will chk tomorrow, Im not at the workshop now.
Thanks!!!
frank
Sorry, busy day yesterday ;- (
My MACH 3 version is R3.043.066.
And the controller uses a USB Interface plugin by CNC Robotica, see http://www.machsupport.com/software/plugins/
BTW, Ive discovered another strange behaviour in MACH3, this time when using the Reverse Run. Conditions are similar; if I click on Feed Hold, the on Reverse Run (thats the order, right?), so as to go back over the area just milled, sometimes it works, but sometimes my Yaxis goes wandering off to an area not indicated in the g-codes, other times it happens with the Z axis. Very frustrating. Thankfully, Im milling foam, so no tools broken, no danger, but lots of frustration.
Any ideas?
Frank Norton.
www.franknorton.com
https://www.facebook.com/Cosas3D/
Hi Frank,
It's been strongly suggested that you do not use 066 as there are some issues with it.
I'd try an earlier release. I use Version R3.043.062
Also, Rev Run, among other features, will not work in Demo mode.
Thanks Overoladed,
My MACH is licenced, so that rules out the Rev Run anomaly?
I will try the earlier version to see if the Feed Hold then Cycle Start issue resolves itself.
F
If changing to 3.043.062 does not help, contact the manufacturer of your motion controller and ask if these are known issues with their board and plugin.
Hi Gerry,
Looking at the CNC Robotica board on their website, it looks to be just a USB interface, not an actual motion controller.
Not sure though as there isn't much info there about it.
http://www.cnc-robotica.com/index.php?language=en&osCsid=132e0beedb1e8bb8b1dbef28fb28da2f
Russ
The manual shows how to select it as the motion controller.
And it has a plugin.
http://www.cnc-robotica.com/images/manual-interface-usb-web.pdf
I saw that too, but no configuration instructions at all for the actual device/plugin like others.
Still, a plugin is a plugin.
The translater helped :)
"Once inside the program will be used the Mach3 setup tools, you don't need to configure "Port" or "Pin" of output, these come pre-defined default interface"
Thanks Gerry
Thanks guys for your input on this issue. Something has comne up, and I have to leave aside looking for a solution, but hope to soon get back to it.
Step 1 will be installing the older MACH version, and then tests, and if that fails, I will contact SUCARMO.
Regards, and thanks,
Frank
