Hello
Guest
it is
September 27, 2026, 11:37:26 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
XML file for potential parallel card issue??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: XML file for potential parallel card issue?? (Read 7832 times)
uniquelydc
7
on:
February 12, 2016, 07:20:47 AM »
Here is my xml file. Jog seems to work fine - otherwise system starts at 100% then begins to slow to crawl & stops. PSU voltage seems fine.
Logged
ger21
6,295
Re: XML file for potential parallel card issue??
Reply #1 on:
February 12, 2016, 07:26:56 AM »
Run Drivertest.exe in the Mach3 folder and see if the pulse rate stays steady.
Logged
uniquelydc
7
Reply #2 on:
February 12, 2016, 07:43:31 AM »
Running the driver test - says system excellent - pulsing between 25281 to 25400
Logged
Print
Pages:
1
Go Up
« previous
next »
