Mach Discussion => General Mach Discussion => Topic started by: uniquelydc on February 12, 2016, 08:20:47 AM
Here is my xml file. Jog seems to work fine - otherwise system starts at 100% then begins to slow to crawl & stops. PSU voltage seems fine.
Run Drivertest.exe in the Mach3 folder and see if the pulse rate stays steady.
Running the driver test - says system excellent - pulsing between 25281 to 25400
