Hello Guest it is October 30, 2026, 08:08:30 AM
Author Topic: driver boards flash when jogging, no output to motor  (Read 20300 times)
« on: February 11, 2016, 10:05:27 AM »
I have watched hours of video and scoured the internet for help....
I have followed many tutorials to set up my cnc... Problem is, the DRO shows movement on all axis', the driver board flashes when the DRO shows movement. I have no action at my motor.
1. Any ideas on possible problems?
2. What voltage should the board be putting out to the motoe when it is jogging? Other ways to test this?
tia, Mike
Components
Mach 3 on XP comp (used register fix)
SainSmart New 4 Axis TB6560 CNC Stepper Motor Driver Controller Board Kit,57 two-phase,3A
3PCS Nema 23 CNC Stepper Motor 2.8A 179oz.in 56mm Bipolar for Hobby CNC Kit
Dc 24v 15a Switching Power Supply Transformer Regulated
Re: driver boards flash when jogging, no output to motor
« Reply #1 on: February 11, 2016, 10:38:42 AM »
Do the motors lock up when power is supplied to the driver board?
« Reply #2 on: February 11, 2016, 10:46:07 AM »
No lock up. I'll verify that again later. Nothing on the mutimeter when the board is flashing either
« Reply #3 on: February 11, 2016, 11:12:07 AM »
If the motors don't lock up, then the drives aren't working. Do they require an enable signal?
« Reply #4 on: February 11, 2016, 07:19:27 PM »
the board requires 5v , I measured at 4.5v. Is this difference enough to be the problem? I'm using the USB for this power
I'm only testing Z
4 inputs from the BOB to the st 330 driver board
         powered
         no action       jogging
step   .1-.2 v            .1 v
dir     4.5 v             Z- drops it to .2 v , push Z+ and it returns to 4.5
en     .3 v
+5v   4.5 v             4.5 v
« Reply #5 on: February 11, 2016, 07:25:43 PM »
Maybe this attachment will help?
« Reply #6 on: February 11, 2016, 11:48:29 PM »
I figured it out. I didn't have enable checked
