Hello
Guest
it is
November 07, 2026, 02:16:44 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach Screens
Screen designer tips and tutorials
Screen4 strange behaviour
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Screen4 strange behaviour (Read 20948 times)
TadyTheFish
21
on:
February 04, 2016, 08:01:25 AM »
Hello im trying to edit some screens in Screen4. When i open a lset file i san select buttons and images in the screen, but as soon as i move a button i can't select it anymore.
Does anyone else experience this strange behaviour?
im using Win 8 and the latest Screen4
Thank you!
ger21
6,295
Re: Screen4 strange behaviour
Reply #1 on:
February 04, 2016, 08:05:16 AM »
Are there scroll bars in the design window? If so, you'll have a lot of issues with Screen 4. If the entire screen does not fit in the Screen 4 design area, than it can be very buggy. You might want to look into Mach Screen.
TadyTheFish
21
Reply #2 on:
February 04, 2016, 08:36:59 AM »
yes there are scrollbars. im usin 1600x900 screen size.. i will try smaller!
i have Mach screen but i have other problems with it! One time i opened the program the work area just dissapered .. only the little editing window opens... can't do anything. i tried reinstalling with no siccess
so i abandoned Mach screen
Thank you!
Klaus1311
531
Reply #3 on:
February 05, 2016, 02:15:02 AM »
you can hold down the shift key and start MachScreen. Keep Holding the shift down until you see the MachScreen window.
Klaus
The brain isn't a soap, it doesn't shrink when used.
TadyTheFish
21
Reply #4 on:
February 05, 2016, 03:02:55 AM »
Not working... I get An error a few times. Parameter is incorrect
Klaus1311
531
Reply #5 on:
February 05, 2016, 05:47:45 AM »
delete registry key HKEY_CURRENT_USER\SOFTWARE\KD-Soft\MachScreen
TadyTheFish
21
Reply #6 on:
February 05, 2016, 06:07:05 AM »
It worked!!! Thank you so much!! I need to write down this fix if it stops working again!
Thank you!
Klaus1311
531
Reply #7 on:
February 05, 2016, 08:22:23 AM »
You don't have to. I'll release a Version where you can do that using MachScreen's menu
Klaus
Print
Pages:
1
Go Up
« previous
next »
