Hello Guest it is November 09, 2026, 04:21:32 PM
Author Topic: Text engraving wizard save  (Read 16409 times)
« on: March 11, 2006, 06:19:34 PM »
Can any one help,
when I use the text engrave wizard it works fine in the current session but if I save the g-code with a file name and restart Mach 3 at a later time and reload the code it displays some of the text with large circles or swirls and tries to cut that path. this happens with Helvetica font ( which is one of the only single line fonts in it ) or any font that has smooth curves.
is it possible that something  is not being saved with the code that is set when the wizard is first run?
chuck
Re: Text engraving wizard save
« Reply #1 on: March 11, 2006, 07:02:58 PM »
think I found the solution my self -- in config/state set IJ mode to absolute. seems to work
Offline BWC
  •  6 6
« Reply #2 on: November 10, 2014, 04:43:22 AM »
I just signed up, searched for and answer to my introduction posting and found this on my first search WOW.
I solved th problem by changing from Absolute to Incremental.
