Hello Guest it is October 20, 2026, 02:57:57 PM
Author Topic: MPG  (Read 74548 times)
Re: MPG
« Reply #60 on: February 04, 2016, 12:40:55 PM »
You're right, I forgot about that one  Well you obviously can't have it both ways. In case you need 0-10V to control the freq. converter, then better solution than this one (regarding the wheel specifically) would probably be putting the transistors on the inputs, triggering them with an encoder. That's if you want to keep it kosher, not connecting directly to the LPT...
I only have the small 400W motor on this router, and I plan to use PWM for this, something like this, same motor: https://www.youtube.com/watch?v=i0wqWP1FzwI
But for 0-10V, it is a problem of course...
