Hello Guest it is November 02, 2026, 02:08:08 PM
Author Topic: Problems starting up with lazyturn  (Read 181302 times)
Re: Problems starting up with lazyturn
« Reply #20 on: January 28, 2016, 09:36:04 PM »
The fix for Win 7 is in Members Docs under the  topic RE: LAZYTURN MANUAL, reply #2, based on what Mike wrote. ( a year ago )
Here is the link:
http://www.machsupport.com/forum/index.php/topic,10091.msg206325.html#msg206325
I will update that  reply with new information as it relates to W 8 & 10 when you provide it.
« Last Edit: January 28, 2016, 09:37:45 PM by RICH »
« Reply #21 on: January 29, 2016, 09:11:56 AM »
Works on both windows 8 and 10. I did it awhile ago on 8 and just did it last night on 10 before posting.
Mike
« Reply #22 on: January 29, 2016, 11:52:01 AM »
Thanks Mike for confirming. Will update what is in LazyTurn Manual link.
Appreciate it,
« Reply #23 on: January 30, 2016, 05:47:22 AM »
Hi Rich,
No problem.
THANK YOU for all the hard work, time,and effort that you have put into lazy turn over the years.
Hopefully I will be in a position to use my lathe soon.
Mike
« Reply #24 on: January 30, 2016, 11:49:30 AM »
 :D Rich,
It is working like this!! Thank you for all your help that I received from you.
I have only one question left.
I saw that in lazyturn 1.1 the fine toolpath was skipped while in version 1.0 it was still in.
Was it skipped because in version 1.0 it was not working in the right way or can I still use version 1.0 instead of 1.1?
Kind regards,
Andre Roest
« Reply #25 on: January 30, 2016, 02:27:36 PM »
Andre,
There is a button to create a fine pass in 1.1.
Don't use 1.0, use the latest.
« Reply #26 on: January 31, 2016, 04:46:30 AM »
Rich,
Do I have still the wrong version then?
My version is stated with: LazyTurn Alpha 1.1 Copyright (C) 2008
In this version there is no button Fine Path in the toolbar.
The ony thing is that you can click toolpath>>Fine path >> and when I click on OK then a statement is shoen ! Not yet implemented Stop clicking me! ..:)
Seems to be a pre version 1.1??
Kind regards,
Andre
« Reply #27 on: January 31, 2016, 05:26:48 AM »
this is a photo after trying toolpath>>fine path >> OK
Gives a failure
« Reply #28 on: January 31, 2016, 05:29:04 AM »
Here is the link fro the latest version of LT.
Is that what you installed?
http://www.machsupport.com/forum/index.php/topic,5767.msg95122.html#msg95122
« Reply #29 on: January 31, 2016, 05:31:47 AM »
There are no other LT posted versions after the one posted in reply #28.
Before yes , but after, no!
