Hello
Guest
it is
November 13, 2026, 02:49:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Need help with first retrofit project - won't run
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Need help with first retrofit project - won't run (Read 23413 times)
Rex B
12
Re: Need help with first retrofit project - won't run
Reply #10 on:
January 18, 2016, 09:26:15 AM »
Quote from: magicniner on January 18, 2016, 08:49:05 AM
Try Bx400
When I enter that value it closes the window. I re-open it and find the value set to Oxb
magicniner
265
Reply #11 on:
January 18, 2016, 09:31:14 AM »
Same here, it may be that you need your PP to occupy one of the common legacy addresses (all mine do) for it to work, what PC and OS are you using
Rex B
12
Reply #12 on:
January 18, 2016, 09:35:28 AM »
The PC connected to it now for testing purposes is a newer HP on Win7.
I know M3 wants XP, but I figured I'd be able to get the motor turning on the newer OS.
Maybe not.
The shop PC is older with XP.
Rex B
12
Reply #13 on:
January 18, 2016, 10:37:39 AM »
version R3.043.066
I did enter B400. the config box closes when I hit <enter>.
When I reopen the config>ports and pins the value has changed to 0xb
Tweakie.CNC
9,377
Super Kitty
Reply #14 on:
January 18, 2016, 10:40:48 AM »
Please check that you are using a 32 bit version of Win 7 (64 bit versions do not work with the parallel port).
Rex B
12
Reply #15 on:
January 18, 2016, 11:02:44 AM »
That is probably the issue on this home PC.
I'll take it back out to the shop and try again.
Print
Pages:
1
2
Go Up
« previous
next »
