Hello Guest it is September 29, 2026, 11:03:23 AM
Author Topic: Need help with first retrofit project - won't run  (Read 22736 times)
Offline Rex B
  •  12 12
« on: January 17, 2016, 12:37:32 PM »
trying to get my feet wet with a CNC conversion. Actually, I have 3 unfinished conversions. I'd like to get ONE running at least!
so....
I am retrofitting an Emco 5 CNC. All the OE electronics are gone.
I am using this stepper driver. http://www.xylotex.com/XS3525V202.pdf
....with this stepper motor http://www.automationtechnologiesinc.co ... h256-28-4a
Powered by a 12V 5amp power supply (my 24V PS was DOA)
Running Mach3. I have it all hooked up on my desktop, set the Vrefs per the Xylotex instructions.
Connected the 8-wire stepper using the Bipolar series diagram.
Now I'm getting lockup when I apply power, but I can't get it to jog in Mach3.
Any suggestions welcome.
  •  9,374 9,374
Re: Need help with first retrofit project - won't run
« Reply #1 on: January 18, 2016, 06:01:52 AM »
Firstly, check the manufacturers data sheet to make certain that you have the correct wire connections for that stepper motor ( H256-28-4A ??? I can’t seem to find that one to verify your wire colours). Check that your Xylotex Enable jumpers are in place.
If you are using the Parallel Port then check in Device Manager for the address of your LPT port and check that the correct address is entered in Mach3 for Port1 & that it is Enabled. Then check the Xylotex data sheet to make sure you have the correct Step and Direction pins set in Mach3 (Ports & Pins / Motor Outputs) also that the Step and Direction Ports are set to Port 1.
Offline Rex B
  •  12 12
« Reply #2 on: January 18, 2016, 07:47:00 AM »
I linked to the motor data but the link doesn't work.  Data sheet attached.
I went all through the Device Manager and am unable to find the port address. I did find that it defaulted to LPT3 so I changed that to LPT1
Ports & pins is correct and double-checked.
« Reply #3 on: January 18, 2016, 08:31:10 AM »
And checked it's address and ensured that address is the address selected or entered in Mach3?
Offline Rex B
  •  12 12
« Reply #4 on: January 18, 2016, 08:40:51 AM »
Where do I find the port address?
I am not seeing it in Device Manager
Offline Rex B
  •  12 12
« Reply #5 on: January 18, 2016, 08:44:41 AM »
OK, I found it under Resources, I just did not think it was right.
I am showing
I/O Range   B400-B407
I/O Range   B000-B007
So what number would I enter in Ports and Pins?
« Reply #6 on: January 18, 2016, 08:47:29 AM »
It should be on the Resources tab when you view the port's properties in device manager
« Reply #7 on: January 18, 2016, 08:49:05 AM »
Try Bx400
« Reply #8 on: January 18, 2016, 08:51:51 AM »
I don't know why there's an x in there as the second character in what's supposed to be a Hexadecimal address but when I tried it without it didn't work.
Offline Rex B
  •  12 12
« Reply #9 on: January 18, 2016, 09:24:21 AM »
Also, should have mentioned:  The instructions say the E-stop button should go green when pressed. It does turn off the flashing bars on either side, but no green anywhere near it.  I have tried all sorts of settings on the input signals
