Hello Guest it is November 13, 2026, 02:02:16 PM
Author Topic: Need help with first retrofit project - won't run  (Read 23409 times)
Offline Rex B
  •  12 12
Re: Need help with first retrofit project - won't run
« Reply #10 on: January 18, 2016, 09:26:15 AM »
Try Bx400
When I enter that value it closes the window. I re-open it and find the value set to Oxb
« Reply #11 on: January 18, 2016, 09:31:14 AM »
Same here, it may be that you need your PP to occupy one of the common legacy addresses (all mine do) for it to work, what PC and OS are you using
Offline Rex B
  •  12 12
« Reply #12 on: January 18, 2016, 09:35:28 AM »
The PC connected to it now for testing purposes is a newer HP on Win7.
I know M3 wants XP, but I figured I'd be able to get the motor turning on the newer OS.
Maybe not.
The shop PC is older with XP.
Offline Rex B
  •  12 12
« Reply #13 on: January 18, 2016, 10:37:39 AM »
version R3.043.066
I did enter B400. the config box closes when I hit <enter>.
When I reopen the config>ports and pins the value has changed to 0xb
  •  9,377 9,377
« Reply #14 on: January 18, 2016, 10:40:48 AM »
Please check that you are using a 32 bit version of Win 7 (64 bit versions do not work with the parallel port).
Offline Rex B
  •  12 12
« Reply #15 on: January 18, 2016, 11:02:44 AM »
That is probably the issue on this home PC.
I'll take it back out to the shop and try again.
