Hello Guest it is November 13, 2026, 03:48:38 PM
Author Topic: Manual tool change with Mill Wizard and Mach 4  (Read 11942 times)
« on: January 17, 2016, 12:15:29 PM »
How do I get the machine to stop for a manual tool change after using G code generated by Mill Wizard (e.g. for two lines of holes using two tools)
Re: Manual tool change with Mill Wizard and Mach 4
« Reply #1 on: January 17, 2016, 12:25:48 PM »
I see now that I use the M6 macro.
« Reply #2 on: January 17, 2016, 12:53:48 PM »
Not that simple, I guess.  I put the M6.mcs from the default Mach profile into the Macros directory of the profile I am using, but it looks like it isn't called.  Is there anything else I need to do?
« Reply #3 on: January 17, 2016, 01:23:44 PM »
Config menu then General Config, there is an option there to stop spindle and wait for cycle start.
« Reply #4 on: January 17, 2016, 01:39:09 PM »
Not in Mach 4
« Reply #5 on: January 17, 2016, 01:41:17 PM »
Ah ok never noticed the title but then again why post here rather than the Mach4 section?
« Reply #6 on: January 17, 2016, 02:23:07 PM »
I originally thought this was related to Mill Wizard, but now that I realize it's the way Mach 4 handles M6, you're right - I should post it there.
