Mach Discussion => General Mach Discussion => Topic started by: MitchB on January 17, 2016, 01:15:29 PM
How do I get the machine to stop for a manual tool change after using G code generated by Mill Wizard (e.g. for two lines of holes using two tools)
I see now that I use the M6 macro.
Not that simple, I guess. I put the M6.mcs from the default Mach profile into the Macros directory of the profile I am using, but it looks like it isn't called. Is there anything else I need to do?
Config menu then General Config, there is an option there to stop spindle and wait for cycle start.
Not in Mach 4
Ah ok never noticed the title but then again why post here rather than the Mach4 section?
I originally thought this was related to Mill Wizard, but now that I realize it's the way Mach 4 handles M6, you're right - I should post it there.
