Hello Guest it is October 21, 2026, 07:02:48 AM
Author Topic: Display Mode Button - Not Working?  (Read 13663 times)
Offline Davek0974
  •  2,606 2,606
« on: January 15, 2016, 05:51:37 AM »
Could there be a reason why my display mode button does nothing?
It has this VB code in it ...
value = GetParam("Boundry")
if  value = 1 then
SetButtonText " Job "
SetParam "Boundry" , 0
 else
SetParam "Boundry" , 1
SetButtonText "Machine"
end if
So I am going out on a limb here and guessing the button text should change when pressed but mine always says "display mode" and seems tot do bugger all.
Just wondering :)
Also, is there a zoom-to-fit option anywhere??
« Last Edit: January 15, 2016, 05:54:06 AM by Davek0974 »
Re: Display Mode Button - Not Working?
« Reply #1 on: January 15, 2016, 06:52:47 AM »
Don't have a copy of Mach3 here, but try double clicking in the toolpath window.
No idea about the other issue.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: January 15, 2016, 07:14:20 AM »
Double-Click in my window and it just resets any scrolling etc to standard view
« Reply #3 on: January 15, 2016, 07:17:59 AM »
It fit's the entire toolpath into the window. If your g-code has commands that send it far away from your part, those are included.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: January 15, 2016, 07:24:59 AM »
Not working I don't think then, It does change the cross-hairs at 0/0 to dashed lines but that seems to be all it does, I think the text does not change as this screen-set uses button graphics and not plain buttons.
« Reply #5 on: January 15, 2016, 07:27:14 AM »
Sounds like it is working then.
DO you have the correct values for your softlimits? That's what tells Mach3 what the table size is.
Offline Davek0974
  •  2,606 2,606
« Reply #6 on: January 15, 2016, 07:28:14 AM »
Fixed it !
You have to press "Regen Path" after pressing the display mode button, I have added DoOEMButton(160)'Regen Path to the display mode button now and it all looks better, the text will not change but hey-ho ;)
