Hello Guest it is October 21, 2026, 09:57:46 AM
Author Topic: mach3 wire up CNC to start plasma HELP PLEASE  (Read 28602 times)
Re: mach3 wire up CNC to start plasma HELP PLEASE
« Reply #10 on: January 15, 2016, 09:44:31 AM »
Here I show what I do not know. I have a c10 board from automation technology Inc .com.I had to tyupe in c10 in the search and at the bottom I clicked on wiering .Thanks again.
Offline Davek0974
  •  2,606 2,606
« Reply #11 on: January 15, 2016, 09:52:38 AM »
You need something like the blue block on this image - this is the relay you need to find.
They can be black, blue, any colour but will look similar.
Have you got a break-out board even??? This will be located at the machine end somewhere.
Please do not just fit any old relay, you could blow your PC very easily.
« Reply #12 on: January 15, 2016, 10:00:17 AM »
Dave, I like this board. Where do I get it. Thanks
Offline Davek0974
  •  2,606 2,606
« Reply #13 on: January 15, 2016, 11:20:05 AM »
Ah, this one...
http://www.automationtechnologiesinc.com/products-page/breakout-boards/c10s-bi-directional-parallel-port-interface-card
that board does not have a torch relay fitted, you will need an add-on board i think.
Personally I would get a more plasma oriented board, opto-isolated and fitted with one or two relays.
If you are building a Plasma CNC you will almost definitely need a THC as well, might be worth your time looking at CandCNC.com I think
« Reply #14 on: January 15, 2016, 11:45:45 AM »
This is what you are looking for.  I would steer away from the CandCNC products as they are far to complicated for the average DIY plasma cutter
https://www.fasttech.com/product/1001100-ttl-250v10a-ac-relay-module
« Reply #15 on: January 15, 2016, 01:06:21 PM »
Thanks. I just ordered this relay . What does the pwm do? I also ordered a Proma thc.
Offline Davek0974
  •  2,606 2,606
« Reply #16 on: January 15, 2016, 01:12:49 PM »
Only advice i can give is to go steady!
Get the machine up and running, making moves, then add the Plasma and debug that, then add the THC.
Do you have a plasma unit yet?
Is the machine built or is this a rebuild/mmodification/change of purpose thing???
« Reply #17 on: January 15, 2016, 01:18:45 PM »
I do have the machine running. I also can cut if I turn on the plasma by hand,I mean turn on and off manually.
Offline Davek0974
  •  2,606 2,606
« Reply #18 on: January 15, 2016, 01:28:30 PM »
Brilliant, thats 95% of the battle won then :)
Sounds like the relay will do it.
AFIK PWM is for motor speed control on stuff like Routers, mills, lathes etc
« Reply #19 on: January 15, 2016, 01:47:18 PM »
wow Dave, I am very happy to know that. I suppose I will wait for my relay and try it out. Thanks for all your help!
