Hello Guest it is October 21, 2026, 02:03:11 PM
Author Topic: mach3 wire up CNC to start plasma HELP PLEASE  (Read 28615 times)
« on: January 13, 2016, 05:31:00 PM »
Hi I am new to CNC. I have a CNC plasma and I can not turn my hypertherm  45 on and off. Do I need something else other then the two wires from the HT 45? Please help. Thanks
« Last Edit: January 13, 2016, 05:39:21 PM by shoer2012 »
Re: mach3 wire up CNC to start plasma HELP PLEASE
« Reply #1 on: January 13, 2016, 06:32:16 PM »
What controller are you using with Mach3, LPT or other ??
(;-)TP
« Reply #2 on: January 13, 2016, 07:23:23 PM »
Thanks for the reply. I am using LPT.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: January 14, 2016, 01:14:13 AM »
Have you got a relay on the break-out board - this is the control for torch firing.
When you press the Torch button on the Mach3 screen you should hear this relay click on and off with the button, if not then that is the area to look in.
Ports and pins set up would be the next area but is specific to the breakout board used.
« Reply #4 on: January 14, 2016, 09:44:17 AM »
The relay you need to access on your breakout board would be the spindle start relay.  IF your Break out board does not have a spindle relay you have to add a relay to the wiring to control teh arc start.
« Reply #5 on: January 14, 2016, 09:51:29 AM »
Thanks. I am going out to try your suggestion right now. I really want to thank you for your help.
« Reply #6 on: January 14, 2016, 11:49:42 AM »
I still can not figure this out.
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: January 14, 2016, 12:37:55 PM »
Any details of your breakout board?
Pictures?
« Reply #8 on: January 15, 2016, 09:17:30 AM »
Hi Dave. I ordered a relay and I will try it when it comes in. I will let you know how it work. Thanks for all your help.
« Reply #9 on: January 15, 2016, 09:36:14 AM »
You cannot just use any relay it must be compatible with the output signal of your board. Can you give us teh make and model number of your breakout board ?
