Hello Guest it is November 06, 2026, 04:35:33 PM
Author Topic: parameters  (Read 9632 times)
rswolff
parameters
« on: January 10, 2016, 12:10:49 AM »
So far I get few answers to what should be simple answers.....I'll try again....
So there are parameters....#1, #2.....I can add, sub, mul and div ( #1=[#2-1] )......any other operations available? such as ABS, INT, etc. and if so whats the syntax?
This shouldn't require a lot of thought.....there must be a listing somewhere......I'd figure it would be in the manual but heck.....i'd be wrong :(
Offline rcaffin
  •  1,073 1,073
Re: parameters
« Reply #1 on: January 10, 2016, 03:29:55 AM »
Yes.
Try Mach3Mill_1.84 (from this web site), starting at page 10-4 (which should be 10-1), and especially at pages 10-11 and 10-12. It's all there.
Roger
  •  9,375 9,375
Re: parameters
« Reply #2 on: January 10, 2016, 04:49:32 AM »
As Roger has said but it’s tricky to find - this may help...
http://www.machsupport.com/software/downloads-updates/
FTP Downloads / FTP Server -  Main Menu  / Docs / Mach3Mill_1.84.pdf
rswolff
Re: parameters
« Reply #3 on: January 10, 2016, 10:51:02 AM »
thanks....found it in the manual.....doesn't do as much as I needed so I'm running the calcs through a macro.  ::)
