Hello Guest it is November 22, 2026, 09:39:39 AM
Author Topic: In order to use F5 as Feed Hold, do I write a script?  (Read 18938 times)
« on: December 30, 2015, 06:53:17 PM »
Before I delve into this, I wanted to see if there's a simple way to assign Feed Hold to a keyboard key.  Thanks.
Re: In order to use F5 as Feed Hold, do I write a script?
« Reply #1 on: December 30, 2015, 07:03:25 PM »
Hit the space bar.
« Reply #2 on: December 30, 2015, 07:06:52 PM »
That worked for me in Mach 3.  Not in Mach 4.
« Reply #3 on: December 30, 2015, 07:11:42 PM »
Sorry, I didn't see it was Mach4.
What about the keyboard plugin?
« Reply #4 on: December 30, 2015, 08:17:25 PM »
I don't see a Feed Hold function that I can assign to a key.  I don't know if that means I need to write one or if it is somewhere that I don't see it.  I see only functions for jogging.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #5 on: December 31, 2015, 12:35:18 AM »
The keyboard plugin is for inputs and feedhold is an output.
You could assign a function of none in the plugin and tie this to an input, then in your plc you can activate the feedhold when this input state is changed.
DazTheGas
« Reply #6 on: December 31, 2015, 07:10:01 AM »
Any chance there are step by step instructions somewhere describing how to do that?
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #7 on: December 31, 2015, 09:59:41 AM »
« Reply #8 on: December 31, 2015, 11:47:24 AM »
Wow.  That's great.  I'm looking forward to trying it.  Thanks a lot.
« Reply #9 on: December 31, 2015, 09:51:41 PM »
Is there a reason you put this in the PLC script instead of the Signal script?
