Hello
Guest
it is
November 22, 2026, 09:27:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
In order to use F5 as Feed Hold, do I write a script?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: In order to use F5 as Feed Hold, do I write a script? (Read 18931 times)
MitchB
47
on:
December 30, 2015, 06:53:17 PM »
Before I delve into this, I wanted to see if there's a simple way to assign Feed Hold to a keyboard key. Thanks.
Logged
ger21
6,295
Re: In order to use F5 as Feed Hold, do I write a script?
Reply #1 on:
December 30, 2015, 07:03:25 PM »
Hit the space bar.
Logged
MitchB
47
Reply #2 on:
December 30, 2015, 07:06:52 PM »
That worked for me in Mach 3. Not in Mach 4.
Logged
ger21
6,295
Reply #3 on:
December 30, 2015, 07:11:42 PM »
Sorry, I didn't see it was Mach4.
What about the keyboard plugin?
Logged
MitchB
47
Reply #4 on:
December 30, 2015, 08:17:25 PM »
I don't see a Feed Hold function that I can assign to a key. I don't know if that means I need to write one or if it is somewhere that I don't see it. I see only functions for jogging.
Logged
DazTheGas
778
DazTheGas
Reply #5 on:
December 31, 2015, 12:35:18 AM »
The keyboard plugin is for inputs and feedhold is an output.
You could assign a function of none in the plugin and tie this to an input, then in your plc you can activate the feedhold when this input state is changed.
DazTheGas
Logged
MitchB
47
Reply #6 on:
December 31, 2015, 07:10:01 AM »
Any chance there are step by step instructions somewhere describing how to do that?
Logged
DazTheGas
778
DazTheGas
Reply #7 on:
December 31, 2015, 09:59:41 AM »
This should sort you out
http://www.machsupport.com/forum/index.php/topic,31585.0.html
DazTheGas
Logged
MitchB
47
Reply #8 on:
December 31, 2015, 11:47:24 AM »
Wow. That's great. I'm looking forward to trying it. Thanks a lot.
Logged
MitchB
47
Reply #9 on:
December 31, 2015, 09:51:41 PM »
Is there a reason you put this in the PLC script instead of the Signal script?
Logged
Print
Pages:
1
2
Go Up
« previous
next »
