Hello Guest it is November 22, 2026, 06:41:08 AM
Author Topic: PoKeys57E can this be used on a 64bit OS  (Read 7658 times)
« on: December 29, 2015, 12:42:39 AM »
I have been looking at building a new control box for my mill.  I was looking at this controller PoKeys57E.  I am using Windows10 and my computer is a 64bit OS.  Will this board work on my system?  Another question is, how hard is this board to setup with Mach3 versus the ESS Smoothstepper and a C32 Board?
Jeff
Re: PoKeys57E can this be used on a 64bit OS
« Reply #1 on: December 29, 2015, 10:33:45 AM »
From what I see there are not many people using it . At least here you do not see a lot of activity .  The board should  run in W10 if the plugin supports it and it should.
Most of your support will probably end up from the Manf themselves .  CNC4PC does have a lot of accesories for it for expansion .
Let us know how it works out for you.
