Mach Discussion => General Mach Discussion => Topic started by: ballistic42 on December 29, 2015, 01:42:39 AM
I have been looking at building a new control box for my mill. I was looking at this controller PoKeys57E. I am using Windows10 and my computer is a 64bit OS. Will this board work on my system? Another question is, how hard is this board to setup with Mach3 versus the ESS Smoothstepper and a C32 Board?
Jeff
From what I see there are not many people using it . At least here you do not see a lot of activity . The board should run in W10 if the plugin supports it and it should.
Most of your support will probably end up from the Manf themselves . CNC4PC does have a lot of accesories for it for expansion .
Let us know how it works out for you.
