Hello Guest it is October 21, 2026, 07:30:18 PM
Author Topic: find a circle centre and radius from three points on a arc - How?  (Read 8917 times)
Wizards now seem to be appearing that will find the centre and radius of a circle from three points on a arc.  Can anyone help with the maths for this so that I can create the appropriate G code.
Is it possible to produce a modified centre finder in the shape of a sword, whereby the tips of the handles touch the arc at a fixed distance apart and the top of the handle slides to touch the arc. A datum line at centre of the sword then gives a reading of the radius and hence you have the centre and radius.  A depth micrometer could possibly be modified.  I do need the maths to try this though as I presume that the scale will be non-linear.
John
Re: find a circle centre and radius from three points on a arc - How?
« Reply #1 on: May 10, 2007, 11:03:42 PM »
John,
look on the web for 3 Point Arc and you should find what you are looking for.
Brian
www.newfangledsolutions.com
www.machsupport.com
