Hello Guest it is October 24, 2026, 08:13:23 PM
Author Topic: Arduino, Mach4 and ModbusIP.  (Read 26880 times)
« on: December 13, 2015, 10:58:13 AM »
I have a need to be able to do certain tasks with arduino and Modbus and have tried to put together a system. I can make a connection but I continually get a Illegal Data Address error when trying to poll for data in the holding registers.
Setup:
Arduino Unu R3
Arduino Ethernet2 board
Mach4
Ethernet2 library from arduino.org
Andre Sarmentos ModbuisIP Library https://github.com/andresarmento/modbus-arduino
Pic1 shows Mach4 with two Modbus setups, modbus0 is connected to the MODBUS Simulator
modbus1 is connected to the arduino through TCP 192.168.1.120
Note, modbus1 has no functions assigned, it's just connecting
Stay with me here...
Here is the arduino code that is simply checking 5 A-D floating inputs and sending that data across the Modbus in registers 40011 through 40015:
read the comments in the code:
  Modbus-Arduino Example - TempSensor (Modbus IP)
  Copyright by AndrĂ© Sarmento Barbosa
  http://github.com/andresarmento/modbus-arduino
#include <SPI.h>
#include <Ethernet2.h>
#include <Modbus.h>
#include <ModbusIP.h>
//Modbus Registers Offsets (0-9999)
const int reg1 = 40011; //Setup the holding register numbers to use
const int reg2 = 40012;
const int reg3 = 40013;
const int reg4 = 40014;
const int reg5 = 40015;
//Used Pins
const int sensorPin1 = A0; //setup the A-d
const int sensorPin2 = A1;
const int sensorPin3 = A2;
const int sensorPin4 = A3;
const int sensorPin5 = A4;
//Instanciate the ModbusIP object
ModbusIP mb;
long ts;
void setup() {
  Serial.begin(9600);
  // The media access control (ethernet hardware) address for the shield
    byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
    // The IP address for the shield
    byte ip[] = { 192, 168, 1, 120 };
    //Config Modbus IP
    mb.config(mac, ip);
    mb.addHreg(reg1);//Create the registers based on the values above
    mb.addHreg(reg2);
    mb.addHreg(reg3);
    mb.addHreg(reg4);
    mb.addHreg(reg5);
    ts = millis();
void loop() {
   //Call once inside loop() - all magic here
   mb.task();
   //Read each two seconds
   if (millis() > ts + 1000) {
       ts = millis();
       //Setting raw value (0-1024)
       mb.Hreg(reg1, analogRead(sensorPin1));//Send the A-D values through Modbus
       mb.Hreg(reg2, analogRead(sensorPin2));
       mb.Hreg(reg3, analogRead(sensorPin3));
       mb.Hreg(reg4, analogRead(sensorPin4));
       mb.Hreg(reg5, analogRead(sensorPin5));
       Serial.println(mb.Hreg(reg1));
}//END
This code seems to work fine and when I run it and connect to it with a Modbus Master other than Mach4 I see the data
(I couldn't upload more than 4 pics but it ran fine)
I then create the function for modbus1 in Mach4 (pic3)
It is exactly the same as the other read function in modbus0(pic4) except I start at 40011 and only use 5 registers
The result (pic5) is modbus1 throws a Illegal Data Address error. This means that The data address received in the query is not an allowable address for the slave. More specifically, the combination of reference number and transfer length is invalid.
http://www.simplymodbus.ca/exceptions.htm
I've tried changing the starting number in Mach to 0 and to 2 with no luck. Any ideas?
I think this would be a really good thing to be able to do and would allow for easy and fast connectivity to the arduino.
I really don't want to use serial but I will if I have to.
Let me know if you have any ideas or if you have any questions
-Tim
Re: Arduino, Mach4 and ModbusIP.
« Reply #1 on: December 13, 2015, 11:02:22 AM »
It wouldn't let me post the pics the first time :)
« Reply #2 on: December 13, 2015, 12:24:56 PM »
I got it figured out for anyone whos interested.
When Setting up the registers on the arduino, You only specifiy the register position number like this:
const int reg1 = 0;
const int reg2 = 1;
const int reg3 = 2;
const int reg4 = 3;
const int reg5 = 4;
That's because Andre adds 40001 in the Modbus Arduino library to this number to give your final number. The software is Base0 where Mach is Base1. So in Mach you use 1 through 5. I'm watching the arduino update some DROs on my screens without any problems. This is really cool as it allows me to do all kinds of really cool things and push the values to Mach. Feel free to ask if I didn't explain this well or if you want to see more :)
« Reply #3 on: December 14, 2015, 09:22:10 AM »
I made a video if anyone is interested
https://www.youtube.com/watch?v=B0w1lwUv5_o
« Reply #4 on: February 08, 2016, 08:52:52 PM »
Tim,
I watched your video and have read in detail on how to set this all up.  I am trying to duplicate what you have done as a starting point for a project I am working on.  I have the same hardware and same settings but when I view the Modbus Diagnostics I am getting an "Illegal State error"  Any chance you know why this would be happening.   And did you have to config your Ethernet port on the PC at all?
Also did you have to modify the ModbusIP.h file to include Ethernet2.h instead of Ethernet.h
« Last Edit: February 08, 2016, 08:55:36 PM by ksilovich »
« Reply #5 on: February 11, 2016, 09:00:41 AM »
Hey Sorry for the delay in responding.
Yes, I did have to modify the Modbus.h to use ethernet2 instead of Ethernet.
Dang it, I can't remember what the Illegal  state error is but I bet you dollars to donuts it's  the setup count is incorrect between Mach and modbus (Base 1 for Mach and Base 0 for Modbus)
« Reply #6 on: April 07, 2016, 11:15:24 PM »
I have been playing with this. Did you have to uncomment the #define TCP_KEEP_ALIVE in ModbusIP.h folder to keep it running?
Polling it did not work for me.
Thank you
R. Clark
« Reply #7 on: April 09, 2016, 01:53:37 PM »
Hi Sparkey3
Yes, I did have to uncomment the #define TCP_KEEP_ALIVE in ModbusIP.h
Thanks for posting that :)
« Reply #8 on: December 04, 2016, 11:38:04 PM »
Hi
Nice work. I want to use your example for my own project. Can this code work with W5100 ethernet shield and libraty Ethernet(one) and mach3?
Thank you!
« Reply #9 on: March 31, 2017, 06:02:40 AM »
How do you know that the register "X_Axis_DRO" is really the position of the X axis?
Is there a Mach's registers manual?
Tnks
