Hello Guest it is October 21, 2026, 12:22:29 PM
Author Topic: Jog Mode default...Cont.  (Read 9217 times)
« on: December 05, 2015, 03:16:51 PM »
Is there a way to set the Jog Mode to CONTinuous instead of STEP?
Re: Jog Mode default...Cont.
« Reply #1 on: December 06, 2015, 04:44:16 AM »
Sorry....I meant the default startup to CONT, so I don't have to change it from STEP.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #2 on: December 06, 2015, 07:10:10 AM »
Have you tried "save settings" after making the step change? In the config drop down menu?
Sent from my iPhone using Tapatalk
« Reply #3 on: December 06, 2015, 12:06:05 PM »
Hi Fastest1...just tried that and it didn't work!  But thanks for the suggestion.
« Reply #4 on: December 06, 2015, 02:31:06 PM »
It should start up in the same mode that it was in when you shut it down.
If it doesn't, you have a corrupt installation??
