Hello
Guest
it is
November 22, 2026, 09:11:51 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Jog Mode default...Cont.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Jog Mode default...Cont. (Read 9509 times)
krsykes23
83
on:
December 05, 2015, 03:16:51 PM »
Is there a way to set the Jog Mode to CONTinuous instead of STEP?
Logged
krsykes23
83
Re: Jog Mode default...Cont.
Reply #1 on:
December 06, 2015, 04:44:16 AM »
Sorry....I meant the default startup to CONT, so I don't have to change it from STEP.
Logged
Fastest1
920
Houston, TX
Reply #2 on:
December 06, 2015, 07:10:10 AM »
Have you tried "save settings" after making the step change? In the config drop down menu?
Sent from my iPhone using Tapatalk
Logged
krsykes23
83
Reply #3 on:
December 06, 2015, 12:06:05 PM »
Hi Fastest1...just tried that and it didn't work! But thanks for the suggestion.
Logged
ger21
6,295
Reply #4 on:
December 06, 2015, 02:31:06 PM »
It should start up in the same mode that it was in when you shut it down.
If it doesn't, you have a corrupt installation??
Logged
Print
Pages:
1
Go Up
« previous
next »
