Hello Guest it is November 22, 2026, 09:06:50 AM
Author Topic: Different feed rate  (Read 8249 times)
Different feed rate
« on: December 03, 2015, 03:56:08 AM »
HI
Is it possible to have different feed rate in Mach3? One feed rate for cutting and one for moving spindle to next shape.
I mill very small parts in carbon fiber and cut with 50 mm/min and and wish to have a higher feed rate beetween the shapes.
I use a china machine CNC 3040 and CamBam CAM
  •  9,378 9,378
Re: Different feed rate
« Reply #1 on: December 03, 2015, 04:36:03 AM »
I am sure the Mach3 Manual can explain it a lot better than me http://www.machsupport.com/help-learning/product-manuals/
However...
There are G00 rapid moves and there are G01 (G02,G03 etc.) feed-rate moves. The post-processor of the CAD/CAM software you are using (CamBam) should sort all this out for you automatically.
