Hello
Guest
it is
November 22, 2026, 11:41:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Issue with Motor Mapping not showing up
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Issue with Motor Mapping not showing up (Read 8458 times)
barnettch3
3
on:
November 30, 2015, 07:50:48 AM »
Hello All -
I'm new to this board and a couple days new to mach4. I have been running mach3 for a couples years though. However, I'm having trouble setting up my machine to the new system.
This is going to sound like such a simple question but in the axis mapping and motor tuning section there are no "motor" selections being offered. I've been watching the tutorials on how to set up my ESS
and each has shown a dropdown selection option available.
I guess my question is does this selection automatically appear when Mach4 is picking up the attached motors. Or is this something I have to manually input somewhere to get started?
Any help would be great.
Thank you,
Logged
robertspark
595
Re: Issue with Motor Mapping not showing up
Reply #1 on:
November 30, 2015, 12:53:46 PM »
detailed walk through youtube here (thanks to Daz).
https://www.youtube.com/watch?v=HIE0k6mu2yc&feature=youtu.be
Logged
Rob
Albert Einstein ―
“If you can't explain it to a six year old, you don't understand it yourself.”
dude1
1,253
Reply #2 on:
November 30, 2015, 12:54:49 PM »
motor 0 = x axis, motor1 = y axis, motor 2 = z axis, motor4 = A axis, motor5 = b axis =, motor6 = c axis
you have to do the settings in the ESS config first before you map it to mach4, also you have to do a restart after setting the setting's.
Logged
robertspark
595
Reply #3 on:
November 30, 2015, 12:55:18 PM »
Oh.... have you installed the plugin for the ESS.... if so then when you click on the assignment of pins one of the options will be the ESS
Logged
Rob
Albert Einstein ―
barnettch3
3
Reply #4 on:
November 30, 2015, 07:09:04 PM »
Thanks everyone I got it. I was using that exact tutorial but the problem I was having was simply a miss assignment on one of the pins.
Thank you All
Logged
Print
Pages:
1
Go Up
« previous
next »
