Hello Guest it is November 13, 2026, 10:00:33 AM
Author Topic: NFS wizzard Gear cutting  (Read 8714 times)
« on: November 21, 2015, 11:02:46 AM »
I use Mach3 for some years, but now I have a 4th axis I want to cut Gears.
When I set up the job all seems to work fine except the feeding of the Y axis in the material.
When I look to the G code de Y speed is the same as the Material number, so when I choose Aluminum, the feed is 1 when I use Other , the feed is 9, that is still very slow.
Is this a known bug?
Tanks for Answer.
Rien pa3gmi
Re: NFS wizzard Gear cutting
« Reply #1 on: January 12, 2021, 02:52:40 AM »
Not sure if you are still there - did you ever resolve this as I am getting the same issue....
Matt
