Hello Guest it is October 24, 2026, 12:41:20 PM
Author Topic: LazyCam 2 Pro Turn Error?  (Read 39921 times)
« on: May 08, 2007, 08:29:03 AM »
I have attached a couple of files. The dxf is from Autocad and the associated turn tap file generated by LazyCam 2.0x.
Mach 3 is hanging when trying to load the tap file.
LC is generating what looks like impossible k numbers in the gcode for Mach3 to process.
Apologies if this is already in hand for fixing or that my dxf is at fault.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: LazyCam 2 Pro Turn Error?
« Reply #1 on: May 09, 2007, 12:51:49 AM »
this is a known bug and will be fixed for the next update, should not be long.
Graham.
