Hello Guest it is November 17, 2026, 04:56:39 PM
Author Topic: servos not traveling proper distance, new install of 2.0  (Read 41257 times)
« on: May 07, 2007, 05:43:24 PM »
Ive been running tests all day and im at a loss to figure out whats wrong.
I just installed v2.0 and am having trouble figuring this out
Here are the symptoms.
1. The z axis when traveling down 1" only goes down .995  . When I cycle it up and down, it always comes back to perfect 0 but never goes down below .995  .
     This exact .005 error is happening with each Axis. It always arrives .005 short of the mark, but always returns to zero.
2. No matter how much adjusting I do with backlash compensation all my circles are all slightly round boxes. When I de energize the servos and roll them back and fourth by hand, there is zero play.
3. When I run a 350 line gcode file, that has a final depth cut of .225, the actual depth is .350  .
If anyone has any ideas, please let me know.
Rob
« Last Edit: May 07, 2007, 06:15:38 PM by replicaprops »
Re: servos not traveling proper distance, new install of 2.0
« Reply #1 on: May 07, 2007, 09:39:52 PM »
sounds to me like you have some PID loop tuning that you need to do :(
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 07, 2007, 10:51:30 PM »
what is that?
« Reply #3 on: May 08, 2007, 09:11:12 AM »
what are you running for servo drives?
www.machsupport.com
« Reply #4 on: May 08, 2007, 11:04:54 AM »
geckos
« Reply #5 on: May 08, 2007, 11:37:24 AM »
Read your docs about setting your Gain and Dampen pots on the back side of the drives...
Also can you turn the shaft by hand with the servo on?
www.machsupport.com
Offline fdos
  •  326 326
« Reply #6 on: May 08, 2007, 11:59:45 AM »
If you're DRO's in mach are saying -1" and the job is ending up 5 thou short of 1" then I agree with Brian your servo tuning is off.  Or you are losing some steps somehow.
If your DRO's read .995" then there's something else wrong.
Wayne....
« Reply #7 on: May 08, 2007, 01:41:49 PM »
So even though the drives have been running fine for over a year, you thing I need to tune the drives again?
Offline fdos
  •  326 326
« Reply #8 on: May 08, 2007, 01:56:21 PM »
Well who knows!    If you tell mach to move say 1"  what do the DRO's in mach say?
If it's been working ok for a year and not now then something has changed surely?
In one of the cases you gave above the distance fell short, in the other it gained?
Wayne....
« Reply #9 on: May 08, 2007, 03:25:43 PM »
I was running a file and I noticed the z was droppng, so I sat and watched the servo and the servo was slowly lowering the Z. The DRO in mach 3 was remaining constant at a set level even though the servo was moving. I had an extra servo, so I swapped them out and it did the same thing. So I think the servos and the encoders are ok. With the servo turning and mach 3 not compensating, what does that mean?
